Results 1 to 8 of 8
Thread: need cam help
    Dec 2011
    maine
    need cam help
    just bought my buddys truck a month or so ago and its a beast to drive but it doesnt have a cam and im looking to put one in but i cant find one i like any where its mainly a street truck maybe hit the strip once a month but its got a lq9 out of a 04 ss with vet heads and a nelson tune. would a 114 lsa be too much or what?
    05 RST with 04 LQ9 swapped with cast 243 vet heads and servo pacesetter long tubes into corsa db with cat and rear o2 delete nelson tunes and a built 4l60e.
    Quote Originally Posted by 6.0l Rst View Post
    no headers? a 114 lsa will make it sound close to stock pending on exhaust, most people look for a cam on the 112 lsa. something that isnt so radical would be around a 224/228 id look into a 581 lift cam.
    first id look into a good exhaust with headers though. at lease a 3" Y pipe even 3" duals would be nice
    Simple: 408 on steroids!
    single digits coming soon!
    Dec 2008
    South Carolina
    i put a custom grind cam on a 114 lsa in a forged iron block 5.7 i built for a friend and it chops/lopes hard as my cam that is on a 111 lsa... a high lsa doesnt mean it will sound like stock. It mostly depends on the other specs of the cam, overlap being a big role player. A cam with a lower lsa with bring you into the power band lower down in the rpm range but wont have as broad of a power band of the same cam with a higher lsa. Im running a 226/230 .600 lift on a 111lsa in my ls1 and it runs and drives great. Go with a custom grind and skip all the headache of finding a cam you like...just my opinion
    2008 GMC Sierra SLE....370ci LY6 with some goodies SOLD
    Dec 2011
    maine
    sorry it does have pacesetter long tubes into a x pipe with no cats and a corsa db exhaust... and i wouldnt even know where to go for a custom grind cam...
    I'd get a the 228/228 .588/.588 112.
    Jun 2011
    Clarksville, TN
    Try engpwrsys.com or vengeancerd.com they have good cams that would fit what ur looking for. Or you could goto comp cams website n use the camquest app to find one.
    http://www.guerragroup.com/camshaft_help.htm
    http://www.engpwrsys.com/tech-notes/cam-design.html
    either one of these guys could help ya out in a big way!! there very knowledgeable in cams, they work and hand N hand with each other!!
    now to go make my stock cam lope
    Jun 2011
    Clarksville, TN
    [/QUOTE]
    now to go make my stock cam lope [/
    QUOTE]
    Lower idle to 450 n pull some timing, lol. Ppl swear i have a mild cam but its stock, my lil 4.8 sounds like a 6.0 lol
