Results 1 to 10 of 10
Thread: DBW to cable conversion
    Sep 2006
    THE 405
    Didn't know where else to really put this. I'm wanting to put a cable throttle on my truck next year. What's it take to convert? I think I've read where Allen has done this a couple times, hopefully he'll chime in.
    Is it as simple as it seems? Just the pedal and a cable? Not worried about and sensors or wiring, just trying to get an idea what it would take to make it happen hardware wise. Thanks
    2007 RCSB|DTR81 built LSx 3xx|PRC|NX|BOGART|MSD|QUICKFUEL 950 E85|4L80|FTI Converters|Smith RaceCraft|Racepak
    midweststreetcars.com
    Mechanical aspect: pedal, cable, TB.
    thats what i want to do...to me i think cable driven has better response,idk maybe its just me
    Oct 2011
    San Antonio TX
    ^^^^ i knew it wasnt just me
    Best ET 11.54@114 w 1.52 60ft
    Raceweight 4905 lbs.
    Broken Bow, OK
    Are the NNBS PCMs even capable of running a IAC?
    The Garage
    I absolutely HATE my DBW. subscribed!
    Pittsburgh, PA
    youll need the TPS wiring, the IAC wiring as well. you maybe able to un pin then repin
    you could do old style harness with right pcm
    standalone
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
    Broken Bow, OK
    standalone
    But then you have the reluctor ring incompatibility and PCM/BCM communication issues
    Nov 2011
    Arlington, Tx
    What year is it?
    Pittsburgh, PA
    not on phantom's motor and if that was thats a simple solution
    412 Motorsports
