72 c20 5.3 swap electrical question
I have the motor in and engine harness hooked up, using 2000 ECM and stock fuse block. Question- what do I do with the 4 wires that were in the voltage regulator? I am using the alternator that came with the engine (and all accessories). So I assume the motor should all be fine as far as power but I need to get power to the chassis and interior, What have you done?
- You may not post replies
- You may not edit your posts
