Results 1 to 2 of 2
Thread: Please clarify this 4 wheel drive issue,
    Jan 2011
    Bradenton Fl
    i blew the stock g80 rear end, which really was a good setup from stock, didnt feel like paying for a posi unit so i stuck a open diff carrier in it, figured it would get me on the road and it was cheaper well i HATE it, anyways in 4hi or 4 lo dont matter before it blew i could hook up to a truck to pull them out of the mud and all 4 wheels would spin, now i got the open diff, every time i hook up to say the front end tow hooks, in 4 wheel, hi or low, it just spins the back wheels only ,the front try, if i just am mudding 4 wheels works great, just everytime i try to pull someone out makes my truck look like a sissy, so point is the open diff causing the the problem? i really want to get rid off this pos open diff.
    2000 Chevy Silverado z71 reg cab, 5.3l procharged, dual exhaust straight piped, custom tune, 200,000 miles, 4 trannys, custom built drive shafts. two speed auto track t-case.
    Feb 2008
    Texarkana tx
    yes, the transfer case senses the rear tires are spinning therefore its going to send the power to them.
    2002 RCSB Z71, 409 with stock heads, custom spec cam, vic jr intake, t-76 Q-trim front mount, Tim Frost 4l80e trans, eaton posi, and the list goes on.
