Results 1 to 10 of 36
Thread: Stage 1 kit, 1800.00 Slightly used.
    Oct 2006
    Wichita Falls Tx.
    Stage 1 turbo kit. Used roughly 100 miles on it since it was installed. 1800.00 OBO
    Kit has a MP 70, 44mm blow off, 38mm gate with a 4psi spring.
    Kit was installed on my test truck (thats for sale) and never pulled off. We are now returning that truck to stock.
    Kit is a good kit, with the addition of an inter cooler could make 550hp. Comes with our swept runner thick wall manifold, 3" downpipe, and 2.5 crossover. The pick below is all the parts that come with this kit.
    Down pipe already has a wideband bung welded in..
    Attachment 3571
    Simply the best turbo kit for late model GM trucks.
    Custom fabrication to fit your budget and needs.
    Dealers for Precision, Comp. & Magnum turbos.
    Online Store
    [/CENTER]
    Nov 2009
    Tucson,AZ
    How much would it cost to add an intercooler?
    chevyboy.520
    06 ecsb 5.3, FAST LsxRT 102, FTI cam! LT's, tru dual, magnaflow, 3400 stall, Performabuilt lvl2, 4.10s!
    PRC stg 2.5 5.3 heads Awaiting to go on!
    Best deal ever.
    Nov 2009
    chicago, il
    So you're saying for $1800 I can have a turboz on my truck?
    Dec 2008
    South Carolina
    it sucks to be broke
    2008 GMC Sierra SLE....370ci LY6 with some goodies SOLD
    Oct 2006
    Wichita Falls Tx.
    Quote Originally Posted by chevyboy.520 View Post
    I have a water to air core I was going to use, I can let you have with the silicone couplers for another 75.00.
    You would still need some other items
    Water tank (I can sale a composite tank for 100.00)
    water pump
    heat exchanger
    misc. hoses.
    Quote Originally Posted by truckinL33 View Post
    Correct.
    Online Store
    [/CENTER]
    Arizona/Utah
    How much to add an air to air?
    Oct 2006
    Wichita Falls Tx.
    You can DIY from ebay for a few hundred dollars.
    For us to build one that is a direct bolt in would be 600.00.
    We are slammed with a project and will not be able to get to building the IC kit for some time.
    I can help up pick out a core if you like.
    Rick
    Online Store
    [/CENTER]
    Nov 2009
    Tucson,AZ
    Is this kit capable of 10psi? If a intercooler was added
    chevyboy.520
    With an IC it would be capable of more than 10psi.
