Electrical Help
I need help diagnosing an electrical issue that recently came up with my ECSB 2001 Silverado. Last night my alarm started going off, honking the horn and flashing the lights. I rush outside to find the truck still locked and nothing out of place. I notice the interior lights (over head light, and door lights) would not extinguish when the doors were both closed or when you start the vehicle like they normally did, and the only way to get the lights off was to use the dome over-ride switch on the headlight control panel.
This morning I go out there to investigate a little further. While sitting in the truck I notice that the SECURITY light flashes the whole time and never goes out. Once locked the SECURITY light illuminates and also never goes out. The only way to get the interior lights turned off is by using the dome over-ride. I think I have a bad door closed switch (for lack of a better word), but I wanted to get this on here and see if any of you have experienced this and have a simple solution.
There are no visible switches for either door (that I saw) so where are those guys located? Unfortunately my truck doesn't tell you if you have a door open like my wife's 04' Tahoe, so I'd have to look into each door I guess. I may be way off base with the door switch so I am open to any suggestions, but that was the only thing that made sense to me.
2002 Silverado 2500HD LB7 CCSB LT
EFI Live by Rob at ATP, Edge CTS Insight DSP 5 control, S&B CAI, PPE boost valve, Pro Fab AIH, AirDog II 165, PPE WIF sensor delete plug, 5" stainless exhaust, Cognito braces & HD tie rods, H2's 315/70 R17 BFG's
2004 Tahoe LT
2006 Silverado Z71 LS
1971 Chevy C10
