Results 1 to 10 of 16
Thread: zo6 cam worth my time?
    Oct 2009
    huntington indiana
    alright, i have a 2004 zo6 vette cam and yellow springs with 2500 miles and a comp cams roller chain that i had given to me by a friend, $0. my truck is procharged, and most of the major mods are in my sig. my questions are- is it worth my time or should i pawn it off and get something else? if i install it what kind of gains or losses should i expect and in what rpm range? my avalanche is my dd and toy and sometimes sees heavy trailers. personally i would rather drop some cash on a different cam if the gains and loss of mpg arent worth my time. i dont wanna waste time and $ on a few hp, im into instant gratification lol. thanks
    procharger p1sc, nelson tune, 42# marine injectors, walbro 255, lt's, ory, 4" volant cat back, PerformaBuilt level 2 pro race trans, trans. cooler with e fan, 2500 stall, aem wideband, energy bushings, spohn perf. trailing and panhard rods, mb & gear alloy 22's ( ya 2 sets, im big ballin), ss brake lines, drilled & slotted rotors, bla bla bla bla bla bla bla,
    and ya it will beat a hemi.
    Aug 2010
    Cannon Falls Mn.
    IMO I would just get a cam speced for your setup and do it right the first time. I think you will be alot happier with the gains.
    99 4x4 5.3 NELSON TUNED / 02 Ls1 CAM / 02 Ls1 "241 Heads" Port/Polish milled .045" / 03 INJECTORS / AIR RAID JR. INTAKE / PORTED THROTTLE BODY / TR55's / EGR DELETE / E FAN's / CAT DELETE / EXHAUST DUMPED
    Headers, Transgo HD2, 3200 stall, 4.56 gears coming soon.....
    Jun 2010
    West Texas
    I was gonna do this cam before but decided to go little bigger with more lift. That Avalanche is pretty heavy so you need more. I put a 220/220 .581 .581 112 in mine and it has good torque down low and all the way up top. Really surprised me cuz I thought it was gonna loose low end. It is a baby cam but I think its just right for what I want right now. The Z06 cam would probably give you bout roughly 10-15 hp over stock and better mileage. I actually gained MPG's with the Comp Cam. Hope this helps.
    RUN WAT U BRUNG!!!!
    Arizona/Utah
    Are you refering to the z06 cam or the LS6 cam?
    Houston
    a 04 z06 cam... which is a ls6 cam
    No its not worth your time
    Dec 2008
    South Carolina
    The ls6 cam is a great cam for boost..not sure if it was this site or performance trucks but a guys made some crazy numbers on a dyno with ls6 cam and boost in a 4.8. i used a 04 ls6 cam in my N/A 5.3 and then switched to a tr220 cam and didn't gain a dam thing at the drag strip and both felt like they made about same power
    2008 GMC Sierra SLE....370ci LY6 with some goodies SOLD
    Oct 2009
    huntington indiana
    ya, 15 hp is not worth messin with. after the work and $'s spent getting it in the truck i would be less than happy. with the weight of my avalanche i would like some more umph off the line, the converter i got dose not feel like it has any stall so a cam that would only gain up top would hurt bad, i herd the zo6 cam makes good power down low?, but i guess thats why i started this thread. i read some posts saying some cams are making 100+ hp at the crank, is that even possible? thanks
    that cam sucks,i ran it with my maggy it was ok...ran it n/a too and no it aint worth it
    Dec 2008
    South Carolina
    yea it will def kill your power down low...
