Thread: DBW trouble
    May 2010
    so cal.
    DBW trouble
    I'm having some trouble getting my DBW pedal to work. When i plug the connector in from the TB to TAC module, the butterfly moves around then stops. I can't get it to move with the pedal at all. I tested the pedal position sensor and I'm not getting any type of resistance reading at any throttle position on any of the pins. Is their supposed to be resistance on any of the pins on the pedal pos. sensor? If someone has the schematic that would help a lot.
    Thanks
    SOLD:1992 ECSB Silverado lm7 5.3 Swap, TR220 cam, Circle D 3200stall, CBM street tune, Schoenfeld LT's, LS1 efans, transgo hd-2 60e, custom CAI, Autometer gauges
    Best 1/8 E.T. 8.86 @ 77.8 on 275/60/15 MT ET Streets with 1.92 60 ft.
    2000 RCSB 4x4 Lq9 swap...stock except mild 4l65e....for now
    May 2010
    so cal.
    Anybody?
    May 2010
    so cal.
    Got it worked out. Ended up being the VATS security. I had my tuner take it out and the DBW started working.
