HELP!! nnbs turbo setup with fuel problem
ok to start off i did a Trick Performance front mount turbo setup about 4 monthes ago including a couple supporting fuel mods, walbro 255 fuel pump, 44lbs injectors. The truck has done flawless up untill yesterday i poped the code p2635 and p069e and my exhaust went from a full healthy sound to a hollow empty sound with a little hesitation. With all this being said it still runs great and feels right it just sounds like hell and is pulling codes. So today i put a new pump in and i still have the same problem. could it possibly my tune and it reacting weird with the Fuel Pump Control Module.
2007 silverado Reg Cab Short bed, circle D 3200 stall, 4L80-E, Trick Performance Turbo 76mm AR96, 44lbs injectors, TSP 220/220 581/581 114lsa cam,PRC double valve springs, Nelson Performance tune, mcgaughy 5/7 drop
2000 Camaro Z-28, Vigilante 3600 stall, 4l65-E trans, LS6 heads, pacestter LT, SLP Airlid, comp 224/230 581/589 114lsa ***SOLD***
2007 Trailblazer SS, Stock
