Results 1 to 10 of 10
Thread: 1st to 2nd hits hard
    Oct 2009
    Stephenville,Tx
    I just had my trans go hd2 and servos installed and from 1st to 2nd gear slams your head against the seat but the rest of the gears shift perfect. would a retune fix this problem or do i need the transmission people to drop the line pressure? it should be stock line pressure
    2006 Chevy ECSB 5.3 - New L33 Motor,CAI, Descreened MAF, Nelson 93 tune, Transgo Shift Kit, servos, 3in exhaust, Borla, pacetter LT's, and ORY, Aeroforce Furture: stall, cam, 4.10's
    Broken Bow, OK
    Put the line pressure back to stock in the tune. How many washers did they put in the servos?
    I have a HD2 and vette servos and with the stock pressure settings in the tune it is perfect.
    Oct 2009
    Stephenville,Tx
    the tune is from nelson and i didnt have any tranny mods when i got it so i figured the he didnt change the line pressure from stock and the tranmission guy didnt change it so i figured it was stock still
    Broken Bow, OK
    How many washers did he put in?
    Gramercy
    my WT does the same thing, i have jacked up line pressure but i added 2 washers or 1 i cant recall and man its hell on the 1-2
    2008 GMC CCSB 6.2/6L80e swap
    Austin, TX
    Did your builder install the 1-2 Accumulator Valve Spring that came with the kit. Mine did the same thing,this's a vid on there about how bad is was, I have to pull the valve body and install the stock spring. If most don't know the 1-2 accumulator valve spring is small about one inch long, that controls the line pressure going to the 1-2 accumulator on the side of the case. I had to install a new spacer plate and not drill out 2nd gear hole, install stock 1-2 accumulator valve spring, install stock accumlator springs with no washers, with stock tranny pressure in tune just to get mine to shift ok, still barks 2nd wot. I think it is my carbon firber band.
    the 1-2 valve spring is 370 or you may have the valve 372 upside down witch would cause very hard 2nd apply
    5.3, E-fans, LPP longtubes w/offroad Y, Dual Magnaflow, K&N Cold Air, 160 thermo, Voodoo 212/218 .531/.531 113 cam, Nelson Tune, 4:11, Built 4L65E, TrailBlazer converter. SOLD
    _____________________________________
    2006 2500HD 6.0L Crew Cab 2WD
    Plainfield, IL
    if it's a nelson tune, can almost guarantee he bumped up the shift pressure...unless you asked him specifically not to. Have him set it back to stock.
    Feb 2010
    Central Texas
    Yep I agree everything I tune I give it more line pressure makes stock tranny shift so much better, better shift quality and feel.
    BB
    Oct 2009
    Stephenville,Tx
    yeah its a nelson tune i changed out my tune with my stock computer and it fixed it its got nice firm shifts but the 1-2nd is neck snappin anymore so must have been tune
    May 2010
    el paso, tx
    mine shifts hard from 1-2 with 10psi still added in the tune. i dont even have the hd2 just the vette servo. like they said above just set the pressure back to stock. either add pressure manually (shift kit) or electronically(tune) not both imo
    06ccsb, cammed, stalled, geared
