Are there any OEM vehicles that came with the LQ9 -and- 4L80E combo? I've looked around a bit but I'm unclear on this. I'd rather not get an L76 or LY6; the LQ9 seems to be really affordable and I'm not interested in dealing with AFM or VVT.
just buy a LQ4/80e complete pull-out and make sure its a 03-06 and just buy a dbc TB.
Were LQ9s built exclusively with drive-by-wire throttles, or are there units available with throttle cables? Maybe I'm a luddite, but I like to know that when I put my foot down, the throttle is opening. I'm just not comfortable with drive-by-wire, no matter how safe and/or awesome it might be.
i run a DBC on my 94 chevy W/T
Is it easy to swap in a complete fuel tank (along w/ pump) from a late model vehicle, or would it be better to re-use my existing tank? Are fuel cells worth the money? I want a 20+ gallon tank, for sure.
how big is your gas tank now? shouldnt it be like 25gal or so?
The biggest sticking point in my mind as far (as having a safe, drivable truck) is the brakes. The stock brakes are pathetic. I'd like to use the front and rear disc brakes from a 94-96 Caprice 9c1, because I know they work great on a heavy vehicle and they fit perfectly with no room to spare underneath the 15" wheels that I have on it now (the ones my grandfather drove around on, which I'm going to refinish and keep on the truck for sentimental reasons).
ive never heard of anyone swap that onto the obs truck, so take it on if you want...but i recommend BAER brakes or something like that if you got the cash to spend. it'll keep you from chasing parts and trying to make this work, and modify this to fit and such forth.
are you wanting this to be a DD/Track truck or are you wanting this to be a road course truck? i cant understand why changing steering boxes and stuff. i would do the 4 link if you want it as a track truck, i wouldnt do it if its going to be a DD. there's a lot of guys running fast numbers with stock suspension and Cal Tracs or other such traction aids like that.
2008 GMC CCSB 6.2/6L80e swap
