Thread: ran last night on the street tires..
    Jackson, TN
    went 9.06 with me(305lbs) and my gf (105) in the truck on street tires. I've did a little weigh reduction. truck is a RCSB 05 5.3 with 4:11 gear, 3500 PTC stall, long tubes and a tune that needs to be re done. last time I ran with 26 11.50 ET streets with 20s on the front, full weight and system it went 8.8 in cool weather. Heres the time slip
    Hers's the 8.8 time slip. that 8.8 pass it spun which it usually dead hooked on the DR's and cut 1.89 60fts but only went 8.9ish
    '05 GMC RCSB 4/6|5.3|LTH-ORY|CAI|4L60E|Transgo HD|Vette Servos|DynoTuned|Tru-Trac|4.11s|3500 PTC|
    4 link, fuel cell and 200 plate kit in the making
    Jul 2009
    man not bad. especially with no cam. not bad 60ft's. bad reaction on the first... you go on the green light.
    04 Silverado Z-71 Extended Cab
    Magnaflow, 10.4 TV 50 wires, tr-55ix, Synthetics, HID's, JL audio, 33.5", leveling kit, tuned, CAI, vette servo, cam, valve job, pacesetter. 9.3@77.5 and 14.5@93.4
    06 2wd
    custom cam, tune, 3.73's, servo, HID's, 10.4mm wires, long-tubes, CAI, magnaflow, 2.5" shackles, Circle-D 3200, UD, JL Audio 4.1, Alpine 5ch
    May 2010
    el paso, tx
    i cant run on street tires at all. tried airing them down to 25psi and still spun both tires bad. 2.5 60's suck. is there any tricks im missing to get better 60's on street tires?
    06ccsb, cammed, stalled, geared
