First of all.... where did everyone run the wires into the cab?
Second, do you have the 'lambda cable' brain box outside in the elements or did you put it inside? I will need to make like a 1" hole in the floor to run cables if that box has to be inside. It only has like a 2 foot extension hose on it, and the oxygen sensor plug is on one side.
The part I'm talking about is boxed in red and probably 2" x 5"
