Thread: Halo projector lamps, led tails, led brake lamp.
Threaded View
    selling them all. set of halo, projector headlamps with led side markers built in, matching parking lamps, anzo rear led taillamps with black background, and the led third brake lamp to go with it. everything you need to set a truck apart from the others! there is an issue with the headlamps though, they function but i have swapped the lows for highs due to the fact the projectors will never stay aimed correctly. one adjuster is broken on the left side. i just switched harnesses and ran on high for low beams and reaimed. ran like that for quite a while. love the halo look and the led's along the sides (3 on each lamp, so 6 per side) look badazz. complete set of 7 lamps shipped anywhere in the states for 300.00.
    2005 crew cab, new crate lq9 with comp 212/218, 558/563 on 115 cam, 80mm t.b. coated long tubes, off road y, flowmaster cat back, dynomax bullet, ngk plugs, msd wires, k&n cold air kit, 4.10 gears, auburn pro lsd, transgo shift kit, nelson drive tune, trailblazer i-6 torque convertor, anzo lamps, ss front bumper, z71 tahoe rear bumper, debadged, kenwood touchscreen with headrest monitors, JL components, coaxials, sub, 5ch amp. bell tech 2/4 drop. 22x10 ss wheels with 285/35/22 bfgs.
