Thread: Dod bypass?
    Dod bypass?
    In The Process Of Swapping in a ly6 with the DOD,,is there any way of bypassing it?will it run even without the plug in the cam phaser?Or what is all needed in order to run?WOULD I HAVE TO RUN THE STOCK 4.8 CAM IN IT any tips/help appreciated..thanks-Zach
    ttt
    Racoon Twp., PA
    This help at all.....I know its carb but....I will keep looking
    6.0l VVT LY6 conversion to carb - LS1TECH
    2013 CC 5.3
    81 C10 LS1 project
    thanks man...
    ttt
    think i found an answer........
    Quote Originally Posted by rgvsierra View Post
    ok, well your gonna have to use your stock cam,timing cover and sproket from 5.3, or swap to the gen 3 style cams, like i did. leaving the stock vvt cam and it will advance it since your truck has no harness connector to control the vvt.
    your gonna have to tune out the dod in the pcm, if not possible right away you can swap valley covers, swapping out valley covers is to prevent the motor from going into a limp mode, due to the connector in back of cover not getting a signal. it will start to sputter/misfire setting several dod codes. but the 5.3 valley cover on the 6.0 will read lower oil pressure in cluster, not sure why.
    while your at it, swap your 5.3 oil pump to the 6.0, its higher volume than the standard 6.0 pump. i did that on mine and it has good oil presure all the time.
    those are the things i went through, and i see your truck is afm. a truck without afm/dod, wont have those problem, but will still have to swap cams out, unless a vendor is selling harness conversions to make the vvt work on trucks that didnt come with it from factory.
    i wouldnt have to worry about tuning out the dod i think.... damm gm why did they try to go green,giving me a headache lol
