well i have put my lq4 back together and bought a beefier ls2 timing chain for it but there seems like there is alot of slack in the chain and i was wondering if this was normal if not what should i do
2006 silverado crew cab z71 6.0
Nelson Tuned
LT
285/75/17 bfg mud terrain km/2
TSP 220
LS2 chain with Ls1 sprockets does have alittle bit of slop
2014 Xsport- 3.5 Eco boost
412 Motorsports
so should i get a ls2 sprocket or will i be okay with my ls1 i dont want my timing to be off or anything to get messed up
Nelson Tuned
LT
TSP 220
probably best to get the ls2 cam sprocket, its meaty to say the least, and if you wanted, you could switch to the front cam sensor, no idea why though. . . but yeah, get a sprocket
www.tjc.edu
ok do you know if its the same 3 bolt
Nelson Tuned
LT
TSP 220
NO reason to switch. The cam sprockets are identical. They both measure .210 thickness. And the gears are identical..
so should i just leave the chain the way it is cause i dont want to much slack in it..
Nelson Tuned
LT
TSP 220
ok and what if i put a damper on it i dont think it has holes for one but was just curious
Nelson Tuned
LT
TSP 220
I don't see a need for one. Unless your reving over 7k and making alot of power..like 600+hp
