Results 1 to 10 of 21
Thread: Best degreaser/de-oiler solution??
    The Garage
    In a nutshell, I'm about to pull my charger pipes off and clean the oil out of them. I was thinking of using brake cleaner and a pressure washer with some rags. What is a good chemical and/or method of getting all the oil out?
    Plainfield, IL
    I used to use wd40 to get the 2cycle oil residue off my dirtbike. Simple green works well too.
    Jul 2005
    Azle , Texas
    +1,Simple Green , cheap engine cleaner from Wally World.
    Sent from a Droid.
    Now what is a tune again?
    Comp Cam 54-412-11 , Int:265, 212, .522 , Exh: 271, 218, .529 , LSA 114 , Longtube , CAI (Vararam) , TransGo HD2 shift kit , tuned by me with EFILive
    The Garage
    So, simple green is a good de-oiler/oil cleaner upper???
    yeah simple green works great
    Maui, HI
    ZEP Purple Cleaner is what I use and it rocks over Simple Green (though Simple Green is good).
    ZEP ZU0856128 Ind. Purple Cleaner & Degreaser Con., Gal.
    99 Silverado 1500 4x4 RC 4.8
    4L60E, 3.73, Homemade CAI, 92oct Quik tuned,
    08 Tahoe radiator/fans, Dumped exhaust... summed up one loud pig caller |[226K! on odometer|
    Mar 2010
    Midland, TX
    Panther Red Soap which is a highly basic/caustic cleaner used in oilfield apps is the way to go if you can get your hands on some....its an awesome industrial degreaser but will irritate the skin
    - 5.3 Stock Internals - Cal Speed Stainless LT's - 18" Magnaflow - K&N Drop In - Airaid Intake Tube - Nelson Tune -
    Shopping List
    - Cam - 3200 Circle D Stall - 10" King Coilover Shocks - 16" King Reservoir Shocks - FG front Fenders - 17" Methods -
    Feb 2010
    Saginaw, Tx.
    TSP (trisodium phosphate) works great on oil and grease, you can get it at any paint of hardware store.
    Nov 2009
    chicago, il
    Basically, there are alot of products that work great. Just don't use oil.
    crc brake clean
