DBC throttle body, tuned DBC PCM, 3bolt intake
I'm going with a 90mm DBW setup this time so I'm trying to clear out some parts.
78mm throttle body w/ TPS & IAC. Very few miles went on maybe a month before the truck was parked. SOLD.
Red/blue PCM that was programed by LT1swap.com, Its set up for a 5.3/60e combo, LS2 injectors, 5-wire MAF, 3:42 gears and has had VATS, emissions, and rear o2's deleted, setup to run electric fans. $85.00 shipped (programing alone was $75)
3bolt truck intake manifold from an 05 Z71, has the brass inserts for a cable bracket so it can be used for DBC or DBW. I also have the fuel rail,stock injectors, cable/bracket but no pics just yet. Make an offer.....please, I'm tired of looking at this thing.
