Results 1 to 9 of 9
Thread: A couple of questions for you sts guys.
    Aug 2004
    Ok, who all is running the sts kit at the standard boost level? The only two that I know of is jerry2500 and bud8fan. What did your MPG do after the turbo. I am just curious what the kit would do on my truck at 5psi or whatever it is out of the box. I am quessing that i would have to upgrade my injectors even for 5 psi. Does anyone have any ideas what kinda times it might run or horspower it might put out?
    04 Sierra Denali
    Blown,Cam'd,stall'd etc.
    Jun 2004
    george west texas
    the best mpg i ever got with this truck was 16.1 and the worst was 12.8 stock.with the turbo i cant lie i actually waisted a new back set of 33" bfg ko's havin too much fun so my mpg aint too good right now but i will get over it one day im prolly gettin 10 right now as i frequent the gas station reguarly...going to install my innercooler and new fuel pump then go back to allens for my dyno pull...you too will get over the fun of burning down a set of tires listening to the turbo whine after a while but i cant give you a time frame right now as im still a newby havin to much f*#kin fun
    '13 silverado LT...stock
    '11 lt 4x4 z71..tvs1900
    Dec 2003
    Newark, Tx.
    With the STS you will usually get a little better mileage. I have broken 29mpg with my Formula a few times since I put the kit on. 27.5 was the best w/o the turbo.
    With a stock 5.3, you should put down 325 - 335. There is a hell of a difference.
    We installed a kit on a truck a few weeks ago, and the customer was very pleased with the sound, power, and quality of the kit.
    You may need injectors even with 5psi. Its not a bad idea either way.
    Mar 2004
    Springfield
    If I'm not mistaken, the standard STS kit is made to bolt right up to a stock truck. No need to change anything out. Injectors should hold up just fine. While you may want to upgrade them, it is not nessary for only 5psi. Now, as far as power, I would say looking at a 100-150hp gain. This is dependant on your engine though. Bigger engine = bigger gain, also More Boost = More power. Fuel mileage should go up, espcially if you keep your foot out of it.
    Couldn't tell ya what the times would be, but expect a couple seconds off your old time in the 1/4.
    FOR ALL YOUR WHEEL, TIRE, AND ACCESSORY NEEDS
    CONTACT: EPLEY'S TOUCH OF CLASSIC 1-270-843-6892
    OR TO GET ME PERSONALLY CALL: 1-615-943-6514
    2000 Chevy Silverado 4.8L RCSB: smoked UPD, Flowmaster exhaust, De-screened MAF, Nelson 93 hot tune. Upcoming installs: trans-go shift kit, Eaton posi, billet servo, ported and polished throttle body...Near future: 6.0/4L80E install with 150 wet shot
    Dec 2003
    I picked up 2 mpg city and hwy. But it may not all be from the turbo. Some the gain is proubly from the tune. And I gained 3 mpg towing and most of that is from the turbo. The engine doesn't have to work as hard pulling heavy loads. But like bud8 said the first few months gas mileage may suck because of the heavy right foot. Which reminds me i need to rotate the tires.
    2000 Chevy Silverado 2500 ECLB w/6.0 , 4L80E auto, 4.10 G80, K&N, Nelson Dyno Tune, 02 PCM STS TURBO , 44# injectors, IC ,HPTuner and 160* thermo 348 rwhp, 394 rwtq @ 5 psi
    60'=2.241
    1/8=9.352@77.39
    1/4=14.40@ 96.67
    Jun 2004
    george west texas
    anymore questions
    Aug 2004
    Um i am not worried about burning up tires as I have all wheel drive. Also I do not have the 5.3 I have the 6.0 325/375 ( Denali version ) I mentioned about the injectors becuase i have heard of people maxing them out on the 6.0 at 5 psi. Most recently bud8fan. The other thing that i am wondering is how well my tranny will hold up to it (4L65E) I do not want to do anything crazy to the truck until the warrenty is up. When that happens I have a whole different motor and will be running high boost via a T-76. Until the warrenty is up I want to keep it simple incase something happens, this way i can yank it off and take it in.
    04 Sierra Denali
    Aug 2004
    Also I cant see the kit at 5psi knocking 2 sec of my 1/4. Right now I have run a 14.4 at 95 mph. 6.4 0-60
    04 Sierra Denali
    Aug 2004
    Thanks for everyones input by the way.
    04 Sierra Denali
