Yes, it is a very good chance you have a bad intake gasket. I speak from experience when i say, its best to go to the dealer and
get GM intake gaskets. The sets you get at an auto parts store sometimes wont fix the problem... lol ask me how i know. they should be black and green in color. GM p/n 89060413.
Also be sure to replace the knock sensor wire harness when you do the sensors.
yes all of this could hurt your mileage as well.
And yes, there were 2 designs from GM. a orange set, and a new improved green set. Make sure you get the green ones. Also when replacing the
knock sensors, i like to put some RTV sealant around the boot above the sensor where they sit in the valley. keeps a little more moisture out
of them that way.
Good luck and feel free to ask any questions if you have any!!
Reason: more to say
2002 Chevy Silverado 2500 HD. CAI, 4.10's, 35x12.50 r17 Kumho Road Venture M/T's. Nelson Tuned.
2002 Z28 Camaro- Small budget cam build. Full bolt on, Custom grind Comp Cam, LS6 intake, 4000 CircleD stall, Nelson Tuned.
2008 Dodge 2500- H&S MiniMax, CAI, DPF delete, EGR delete, AirDog fuel system.
