Results 1 to 7 of 7
Thread: 2003 ECSB Throttle Body
    Lakes Region NH
    The throttle body/harness in my 03 ECSB 4.8 is on its last life, and they need replacing. The dealer was kind enough to offer to do it for 800 dollars, but Id rather do the work myself and upgrade while Im at it.
    What are my options for an upgraded T/B in my truck?
    Thanks in advance,
    Coop
    Ill grab some ditch to get a cat...
    03 Silverado ECSB - SOLD
    06 CCSB Duramax - 12 second tow pig
    Farmington, MN
    Wow, what a bunch of rip-off artists. There can't be much wrong with it, they are very simple. What could be wrong with the harness?
    I don't think a larger TB would be right, if that's where you're going
    2000 Sierra rcss, LS6, xr265hr-15, HP Tuner, B&M, traction, cai, 2-4, 3.73 G80, Centerline, Pacesetters w/custom pipes and mufflers
    I went to the 80mm BBK and I was happy with the results. Make sure to get a new gasket upon replacement.
    Lakes Region NH
    Thanks for the suggestion, do you have a link to the BBK TB? Also is that a DBW TB or a cable TB?
    Sep 2009
    Is the '03 a DBW/ETC or cable? If it's cable you can grab a throttle body off any LQ4 (6.0L HD Truck) as it's an 80mm (5.3 uses 75) and will bolt right on. If it's a DBW/ETC then you can grab a throttle body off any LS6 and some trucks came with them (I believe LQ9's). If you want bigger and if your current setup is DBW/ETC then you can grab an 85mm throttle body off any '97+ Corvette. Any of these could be found for cheap in a junk yard.
    2000 GMC Sierra 5.3L 4x4 ECSB
    Lakes Region NH
    I do believe that its DBW - so best I can tell. Especially with the need for the TB to be replaced as well as the associated pigtail.
    Sep 2009
    Alright, do a search of the junkyards for a Corvette or TBSS throttle body. Corvette will have the 85mm and anything else will have 80mm.
