OK, 2003 Tahoe, 101,000 mile 5.3 flex![]()
Codes:
P0101B (MAF)
P0300B (Misfire)
P0171B (Bank 1 fuel trim lean)
P0174B (Bank 2 fuel trim lean)
Flashing engine light, restarted and it went off. Dirty MAF?
S.C.
Codes:
P0101B (MAF)
P0300B (Misfire)
S.C.
Gone, but not forgotten!
A dirty MAF won't cause misfires or a flashing SES light. You have a more serious problem. Does the truck still have the factory catalytic converters? If so, better have them checked.
Truck is 101% stock. Plugs, wires, cats, etc are all stock. Only oil & filter changes as required.
It was missing out during a cold (cold for Texas) start @ about 28 degrees. Sounded like it had a nasty cam; gave it some gas & it cleared up.
put some new plugs in it, clean the MAF, make sure your plug wires are good. no popped fuses. Clear the DTC's then see what happens
2005 GMC RST *sold
2006 Silverado SS with nawz
sound like cats ,i just went through hell ,finding this out on my escylade
What they said or a vacuum leak. Maybe.
Yeah, flashing SES due to the misfire means the cats are taking a beating.
2013 CC 5.3
81 C10 LS1 project
plugwires!
LOL
Nothing like a unanimous opinion.
Thanks for the responses.
