Thread: Can A 10 Bolt Rear Be Moved Side To Side?
    Oct 2003
    I have the usual 6" rear axle flip on my 1996 1/2 ton two-wheel drive GMC. Is there any reason I couldn't loosen my U-bolts & slide the rear-end back & forth, to center it better in the wheel-wells? Can't remember if there was leaf-spring centering pins or not, that would prevent you from doing this? Thanks
    Nov 2009
    Appleton,WI
    yes there are pins
    Mar 2007
    Austin,TX
    Yes there are pins, but even with the pins the rear end can get off a 1/4". I had it happen. Just reset everything and tightened it back up. No issues now.
    Oct 2003
    Rear Leaf-Springs...
    So, the locating pins are on both the top, and the bottom, of the leaf-spring stack, huh? They protrude out both top & bottom?
    Jun 2009
    Dublin, Ga.
    yes, they have the round stud on bottom of the spring pack and the nut that clamps the springs together on top.
    Oct 2003
    Thank You
    That's right, now I remember that...Thanks for everyones input.
