Results 1 to 5 of 5
Thread: What vehicles came with hydro boost?
    I'm looking to put a hydro boost in my 98 1500. What vehicles can I look for as donor vehicles that have hydro boost? Thanks.
    Quote Originally Posted by Pavetim View Post
    I'm pulling one off of a '95 diesel truck.
    You can probably make the newer stuff work too, like an '05 Avalanche.
    anyone know if the duramax trucks have it? I am thinking of trading the gto in on one.
    Hello, the hydroboost unit off of a NBS, has a different mount plate config. than the obs, 3 holes line up, and 1 isn't even close, it can be swapped for an obs plate off of a core unit, but the brake pedal pushrod is also totally different. It could be done, but def. not without heavy mods. As for donor vehicle, you need 95-2000 3/4 or 1 ton obs for donor, 94 down won't work, different push rods, and they are not easy to change. Take it easy
    Also the o.d. bore on the nbs master cylinder is much larger than the bore on the obs hydroboost unit, so it won't interchange, unless you use a nbs hydro. unit.
