Fully built 4l65e and Yank SC3000 7k miles
Hpm(danny tranny) 4l65e 2WD /w Yank SC3000. condition=excelent (1800$)+ shipping If i have to separate It will be 1550 for tranny and 650 for the Yank
This unit has 7k on it. The tranny works and shifts flawless. If you need to talk to the builder i can get you his number. I dont want to separate the Yank SC3000 from the sale. The Converter still has the free restall from yank if you want it different. this is the billet cover 1000$ converter. Shipping is about 150 on the tranny and 45 on the verter.
Specs on the trans are as follows i have the 1-2 bypassed
Superior shift kit
corvette servo
File fit servo pin
1-2 accumulator piston aluminum
forward accumulator aluminum
rpm spring kit
alto red eagle 3/4 clutch pack with 9 clutches and kollen steals
alto clutches for all other frictions
carbonite wide band with reinforced anchor
entire valvebody blueprinted
rear slinger planetary ( 4 pinion hardened with reinforced ring)
29 element dual cage input sprag
350 lock up front stator bushing
bronze case bushing replaced with babet bushing
bleed orifice drilled in input housing
blocked third gear accumulator exhaust
Beast sunshell
New lock up solenoid
New shift solenoids
New internal wiring harness
Trans go separator plate
- You may not post replies
- You may not edit your posts
