Results 1 to 10 of 10
Thread: Shift light??
    Feb 2008
    Arizona
    Shift light??
    Hey guys, I'm wondering, is there any kind of setup where I can install a shift light in my truck and program each gear's shift point with my stock tach??? I mean without having to buy the aftermarket tach??
    Thanks guys!
    06' Silverado RCSB 5.3L 4wd..
    HID's Hi, Lows & Fogs
    Plainfield, IL
    old school, you just tapped into the coil...granted we have 8 instead of 1, but i'm assuming the theory is the same.
    I'm sure someone else will chime in but you SHOULD be able to just wire the light to one of the coils (i believe it's the - side...i'm not 100% positive, shifty light should say)
    Isn't there a Tach output in the harness?
    Feb 2008
    Arizona
    how would that work bud?? I mean, how will the shift light go on on every shift point??
    Racoon Twp., PA
    Are you using the same RPM for each shift?
    If you are talking about different RPMs for each shift point....I don't think there is such a thing.
    2013 CC 5.3
    81 C10 LS1 project
    Feb 2008
    Arizona
    yeah, I thought about different RPMs for each shift point.. so it cant be done?
    Racoon Twp., PA
    Doubtful. You would need 2 or 3 seperate progrmable lights.
    2013 CC 5.3
    81 C10 LS1 project
    Plainfield, IL
    most shift light have pills...so you can set the rpm. If you want to have DIFFERENT shift points, just use a laptop and have different alarms set up
    spruce grove, alberta
    you could wire it in using a window switch and that will control when it comes on
    2000 GMC Sierra
    6" pro comp suspension
    3" body lift
    2.5" truxx leveling kit
    37" micky thompson mtz
    pacesetter long tubes-offroad y-pipe-no cats-morroso muffler-MSD coils and wires-flex a lite fans-air aid intake-diablo tune
    Pittsburgh, PA
    my shift light is tapped into the white wire that is in the cluster. the white wire is the tach signal.
    heres a thought, Ls1 style motors are 4cyl when using shift lights or tach.
    my shift light is selectable for rpm but only has one rpm input.
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
