As you can probably tell with my handle name, I have an L33 engine. If I'm correct, this engine has 799 casting heads which are the same as 243 casting heads. Does this also mean that I have springs that can support a .600" lift cam? Also, I'm pretty sure that an L33 came with flat top pistons. If this is true, is it possible for me to run a 220ish duration cam with a .550" lift without piston to valve contact? I'm very new to ls engines as you can probably tell.
