Results 1 to 9 of 9
Thread: 2 1/2 or 3 in?(exhaust)
    Oct 2003
    stuttgart,ar
    I ordered some headers today & thought might as well
    change the exhaust too. Should i stay with 2 1/2 or
    go 3in ? And what mufflers to go with it?
    thanks,scott
    2000 SWBRC 5.3,radix,e-fans,no cats,true duels
    2 21/2in delta force race muffs,4.10 with eaton
    e-locker.Descreened MAF & throttlebody bypass.
    FLP level 5 4L65E,PI 3000 stall,Dynatech headers
    Nelson tune
    2005 GMC 2500HD 4door 4x4
    1989 Chevy Suburban 4x4 ( Sir Leaks-a-Lot )
    Nov 2004
    Ashburnham
    You should do a custom exhaust. True dual right from the headers. Two highflow cats. Two sweet thunder chambered mufflers. Although im not sure what happend to the sweet thunder website. It is now a site for jewelry
    anyways you can still find the same ones in summit I think and various places. They look similar to a cherry bomb or glass pack i guess but they are far from it. They are the same thing as the GMMG exhaust for the F-body and Corvettes. It would sound awesome!!! I have these on my truck!
    -Mike
    Jun 2003
    i think a true dual with 2 1/2 inch will be plenty . i would get a couple a mandrel bent pieces for the sharp turns on the drivers side. free flow cats work great but remember that the factory cats work good as well. i run carsound cats on mine. they work good. i am also running a magnaflow hd muffler. 12568 it the poart number. it has a dual inlet and outlet. it also has a true x pipe design inside that will help low end some.
    formerly 02denali 12.79@107
    Sep 2004
    I agree with 02Denali. I have a similar setup
    http://i15.photobucket.com/albums/a3...lla/breeze.jpg 03 Silverado LS, 6.0 RcLb
    Go: Radix 2.9, 100mm Idlers, GT2-3 Cam & Springs, Long tubes, 2.5'' duals, Cut outs, E Fans,
    Built 4l65e, 2600 Conv, 3.90 Gears, Eaton Lsd, Caltracs, Tuned by F-Body Central
    Show: Eagle boss 309, Toyo's 285/50s, SS Bumper cover & Spoiler, Roll pan, 2'' rear drop.
    Track times 12.304 @ 110.30 with a 1.747 60'
    Oct 2003
    stuttgart,ar
    I looked at that magnaflow muff today,looks like
    i'll probaly get one.How does it sound? The cats
    are off already,might not put any on.Stay with
    2 1/2 in right,what do you think a 3 in system
    would do : help it out or will it hurt?
    I hate trying to make my mind up,gives me a
    headach!
    thanks for all the input,scott
    Nelson tune
    Oct 2003
    Milwaukee, WI
    headach!
    I have always liked the mellow rumble of the magnaflows. However I would suggest putting some cats on and using 2.5". Otherwise you won't have enough backpressure with the dual system and you will actually loose power.
    Nov 2004
    Ashburnham
    Deffinately no larger then 2.5 on the dual.
    Jun 2003
    if the cats are off then do the 2 12 dual out. that muff sounds kick ass.
    Oct 2003
    stuttgart,ar
    OK,2 1/2 and magnflow it is. Thanks alot guys
    Nelson tune
