Results 1 to 7 of 7
Thread: need pics
    Nov 2009
    Spring, TX
    need pics
    can someone post some pics on installing a corvette servo, start to finish
    Missoula,Montana
    Check out the sticky on the Home page.
    http://www.ls1truck.com/forums/front...tallation.html
    '00 1/2 TON ECSB 5.3L 4L60E
    K&N Filter,Gibson Exhaust,Superchips Programmer,Billet Servos,'03+ Taillights,White Door Handles,Carbon Metallic Grille Emblem,6000K HID'S
    Servos are easy. Just remove the heat shield, pop the snap ring out, pull out servo--MAKING SURE TO NOTATE THE LOCATION AND ORDER OF INTERNAL PARTS!!! Make sure to install new o-rings--and make sure to only take off the blue and red one at a time to make sure the blue one goes where it is suppose to and the red one goes where it is suppose to... Reinstall in reverse order as you took it out. Also, it is nice to have a little tranny fluid around to help lubricate stuff.
    Nov 2009
    Spring, TX
    should i drain the trans first
    Missoula,Montana
    No You Will Only Lose A Quart Tops
    Ha--not even that. But make sure to have a catch basin below to collect the tranny fluid that does leak out.
    Nov 2009
    Spring, TX
    alright
