Results 1 to 7 of 7
Thread: Lift and Fitment
    Racoon Twp., PA
    Lift and Fitment
    This is what I know fits from my own experiences and will leave you without rubbing the tires. Very minimal if you do.
    99-07 1/2 1500 4wd
    2'' Leveling Kit
    -285/75/16 (33's) on stock wheels
    3'' Body Lift
    -285/75/16 (33's) on stock wheels or up to 8'' wide with slight T-bar crank
    4'' Suspension Lift
    6'' Suspension Lift
    -315/75/16 (35's) up to wheels 8'' wide
    6'' Suspension Lift w/ 3'' Body Lift
    -315/75/16 (35's) up to wheels 10'' wide
    -37's on wheels up to 8'' wide
    2013 CC 5.3
    81 C10 LS1 project
    Plainfield, IL
    99-07 1/2 1500 2wd
    2'' Leveling Kit
    -265/75/16 on 10" wheels
    3'' Body Lift+ 2" leveling kit
    -285/75/16 (33's) on 10" wheels
    7'' Suspension Lift
    7" Suspension Lift
    -315/75/16 (35's) on stock wheels
    7'' Suspension Lift w/ 3'' Body Lift
    El centro, Ca.
    I got 9" wheels on a 6 inch lift. Its all in the back spacing and on which lift you get.
    2005 Silverado 4x4, 6" RCD lift, M/T Classic locks on BFG KM2's, 4:56 gears, Air-raid CAI, TB spacer, Nelson tuned, Corvette servos, 160 thermostat, Ebay long tube headers, Flowmaster Delta 40, Cognito Motorsports steering upgrades. 2000 Ford Lightning, 2.3 KB, bolt ons, 7.67 on the 1/8th.
    P'cola Fl
    Quote Originally Posted by Silverado05 View Post
    I agree 110% i've seen my truck with 6' lift and 315/75/16 on 10" wheels with no problems at all. Which is what im about to run, but thats just my
    03' sierra Z71 slt ecsb 5.3 throttle body coolant bypass, k&n complete intake kit, descreened mass airflow, dynatech long tube headers into dynatech high flow cats with y pipe into magnaflow split duals out the back.
    "I call her trish" ..... cause something this sexy and devious has got to be bad for your health....
    Fort Worth, Texas
    Most lift do require a certain amount of back spacing, but with an inch we're talking a little more cranking or a small amount of trimming to gain the needed clearance.
    I run 37 13.5's on a 10" wide wheel with a 6" and 3" BL, they just needed a bit of cranking to clear and the normal lower valance trimming....
    2002 Silverado 2500HD LB7 CCSB LT
    EFI Live by Rob at ATP, Edge CTS Insight DSP 5 control, S&B CAI, PPE boost valve, Pro Fab AIH, AirDog II 165, PPE WIF sensor delete plug, 5" stainless exhaust, Cognito braces & HD tie rods, H2's 315/70 R17 BFG's
    2004 Tahoe LT
    2006 Silverado Z71 LS
    1971 Chevy C10
    Plainfield, IL
    offset is the main thing. And what brand tires...some 37's only run 36ish
    Racoon Twp., PA
    Good comments guys. Backspacing and lift brands do also make a difference. As well as the tire brand to its sizing.
    Just a quick reference guide mainly.
    2013 CC 5.3
    81 C10 LS1 project
