Results 1 to 10 of 10
Thread: 4.8 cold starting
    Union, MO
    4.8 cold starting
    I have a 2004 Silverado with the 4.8 And was wondering if a slight engine tick is normal when starting the truck in colder weather. It only lasts a few seconds and then goes away. I have 83K on the truck.
    SA, Texas
    Sadly yes! happen to my 4.8L... sticky lifter..
    Her name is A Meli-
    "If everything is under control, you are going too slow."- MA
    Union, MO
    Is there anyway to easily fix that or is it something that I don't need to worry about it? If it's not going to cause any problems then I can deal with the ticking for a few seconds.
    Spring, Texas
    Don't worry about it. It's normal and as long as it goes away after a little bit, you'll be fine.
    Some do it all the time and still have no issues.
    Union, MO
    That's what I like to hear. Thanks
    Jun 2009
    Washington DC
    my 4.8 is an '07 with 20k miles and the valvetrain is also a bit 'ticky', but these are LS motors, so get used to it. Never had a problem with any of these engines (as long as still stock), and Ive had a few of em. Synthetic oil will help with the sticky lifter issue if that's what the problem is (it helped for me at least)
    Quote Originally Posted by medic2967 View Post
    Put a can of Alemite CD-2 into your crankcase.
    Union, MO
    I'm not a big fan of additives. The only thing I've put into the truck is Lucas fuel treatment, and I've always used Mobil1 5w-30.
    Jun 2009
    Washington DC
    Synthetic is thinner oil so in the summer up here in DC I use 10w30. In cold weather I switch back to the recommended 5w30
