Thread: 4l80e swap
    Jul 2009
    Mid-Michigan
    4l80e swap
    In the middle of a 80 swap in my half ton,and wondering if anyone knew the exact amount to add and take off my driveshafts? The truck is an 02 ECSB 4x4.
    Jun 2007
    why couldnt ya just get a front and rear shaft from a hd model truck with an 80 e in it ?unless youre using the 1/2 ton transfer.i bought the hd transfer so im hoping thats what i can do when i do mine.
    Jul 2009
    Mid-Michigan
    Im gonna be running my 1/2 ton transfer case.
