Results 1 to 7 of 7
Thread: trans mysteriously out....
    parked my truck everything was fine truck...put it in the shop to put my tru-trac in got the rearend done 6 weeks later cause i've been workin 7 days a week went to drive it down the road an overdrive will not pull from a dead stop will pull after you get goin but slips badly 1st still works fine 2nd slips a lil and 3rd is pretty much dead...how does a trans go out when the truck is setting still...
    2003 silverado x-cab stepside fully loaded..nelson tune..green CAI..160 thermostat..ls6 intake..pacesetter LT's..3"magnflow hi-flow's..one chamber flow dumped..4L60E PATC 1-2 servo 4th servo..trans go HD-2..ridn 24's...2" 4" drop..detroit tru trac an 4.10's setin n the shop waiting
    Sallisaw OK
    tranny fluid full?
    1996 gmc ext cab short bed
    6.6L 4l80e
    MY GARAGE
    Jun 2009
    Dublin, Ga.
    they don't!
    Plainfield, IL
    they might have pulled the shaft out and you could have lost fluid....check level
    did that first thing fluids checking fine
    Sallisaw OK
    was any work done on the trans recently?
    6.6L 4l80e
    MY GARAGE
    do you have any way to check line pressure.
    Nothing stock...I either broke it or replaced it before I broke it!!
