if so what all is needed?
im really thinkin about doing that to my 5.3... if not just gunna go stright to a 6.0
02 Chevy EcSb Z71, 5.3, Helix Tb Spacer, AEM Brute Froce Intake, Msd 8.5 wires, NGKTR55 IX, B&M 25k Trans Cooler, Hypertech 160, Nelson Tune, Nelson Harness & Ls1 fans, Fully Built tranny, tb2600, 216/224 551/551 115LSA, yeller z06 springs, magnaflow, cut-out, hi-flow cats, etc...
Depends on what you want and what you're building it for...The way I figured it was that I already had the 5.3 and my builder will charge around $200-300 to bore it which was cheaper than buying a 6.0 block and having prep work done on it. Then you just have to buy pistons for the 5.7. You can reuse rods and crank. If you're on a budget, it's not a bad way to go.
You'll need pistons, bearings, rings, heads (compression will be too high with stock truck heads, I went with 317's).
i would go straight to the 6.0 since they can be found cheap
If you are wanting to go forged with a 6.0 or the 5.7, it's the same. What I mean by that is you would have to buy forged parts for both so the cost is pretty much equal. The only difference being if you already have the block or if you have to buy one.
Pistons you can go with Diamond, Wiseco, Probe....
Bearings - Clevite or Federal
Rings - Don't skimp...Total Seal's are good
Heads - 317's will give you lower compression than the LS1's.
What are you building this for? N/A, nitrous or F/I? That makes a big difference as to what parts to put in it.
I have been Planing to do the bore thing w/ my 5.3 and from what i understand running w/ the 5.3 heads would have a compression of around 10.8..
2000 sil.ext. 5.3 / Lingenfelter Ls1 cam / LS1 valves / Ported / Milled / 35lb injectors / 80mm tb / E-fans / cold air intake / Pacesetter Cer LT's w/3"ory/ JET-DST / MSD Twister / Corvette Servo / 3.73's / 125 N2O / no cats / Flowmaster exhaust / level rear drop / Rear sway bar / SS wheels / 285/50R20 Goodyears / 05 Tail lites
all n/a dont really plan on sprayin or anything...
I have the iron ls1 in my truck and built it by myself. I used stock rods and pistons from a ls1 and my stock 5.3 crank. I have the prc 5.3 heads and my motor runs damn good. Have ran a best of 8.3 in 1/8 mile soo far in a rcsb z71.
Go with the 5.7. I would do rods too. But stock crank is ok. Find some ls6 or lq9 heads and a nasty cam![]()
could a 5.3 be turned into a 383? if so how many quarts of oil n such would you need?
