Results 1 to 10 of 10
Thread: valve cover breather line?
    socal
    on the nbs trucks there is a breather line for the valve cover that runs into the air intake. will it affect anything if it is left unplugged for a short amount of time?
    naw man wont hurt anything,i ran mine plugged and unplugged till i drilled and tapped into the cold air i made,but no nothing will happen,but u will hear vacuum.
    socal
    Quote Originally Posted by STUNNA View Post
    alright cool man ill do that. thanks
    GLENDALE,ARIZONA
    Quote Originally Posted by GRsilverado View Post
    Go to your local parts store and get the specktre air breather and cap it like at the TB and put the breather on the hose I did.
    This will stop the blow by oil from mucking up your intake and will give ya just a little MORE POWER!!!!!!
    PICKS INCLUDED
    Alabama
    it wont hurt nuthin
    2007 Silverado. Mostly stock...
    S.A. Texas
    Mine is just open
    Sallisaw OK
    i just put a little air filter on mine and its much better. i wouldn't want the oil and crud coming out of the valve cover going into my intake.
    1996 gmc ext cab short bed
    6.6L 4l80e
    MY GARAGE
    hot & windy
    Quote Originally Posted by midnight04 View Post
    PICKS INCLUDED
    how does that make more power?
    99 Sierra - 5.3 / 5spd
    ff_jeff Guest
    Dont use the little filter. It will get oil soaked, and either wont let the motor breathe like its supposed to, or will eventually start to seep oil out. get a catch can with a filter on top of it. like this.
    http://volvospeed.com/Pics/Review/jazbreather.jpg ----- one line from the passenger side valve cover, one from the driver side valve cover. be sure you put a rubber cap on the intake elbows so you dont have a vac leak.
    Quote Originally Posted by zebra View Post
    By not letting oil in your intake. All that oil is what gums up valves and such. less detonation too. your not combusting oil.
    On an N/A motor held to less than 7K it probably helps as much as a T/B bypass unless you have EGR.
