Anyone know of any sites w/ any tuning info...? Trying to get it dialed in.
2000 sil.ext. 5.3 / Lingenfelter Ls1 cam / LS1 valves / Ported / Milled / 35lb injectors / 80mm tb / E-fans / cold air intake / Pacesetter Cer LT's w/3"ory/ JET-DST / MSD Twister / Corvette Servo / 3.73's / 125 N2O / no cats / Flowmaster exhaust / level rear drop / Rear sway bar / SS wheels / 285/50R20 Goodyears / 05 Tail lites
Are you using HP Tuners? If so they have a forum...CLICK
Not sure about that...
Just a suggestion, and if you've already been bombarded with this, I apologize: I would see if you could sell the Jet and use the proceeds for a live tune with HP Tuners. There are guys in the DFW area here that can do it for you and can do more than the Jet can do.
EDIT: I should say I ASSUME that HP Tuners can do more than Jet. Looks like pretty decent tuning software.
+1 Ftw
If anyone could explain to me what is so much better about HP over DST I may think about it but i haven't found any problems w/DST...my truck runs good, it's just finding info on adjustments is the problem..
That's one of the advantages of HP over something like Jet is the support that is out there. Many top tuners use HP and there are plenty of forums out there to help if you are tuning on your own.
That's kind of what I was going to say...if Jet made the best tuning software...the best tuners would be using it. I'm not familiar enough with HP Tuners let alone Jet's software to say "HP Tuners does this, this, and this, and Jet doesn't". But if you have HP Tuners, it will do everything you need it to with the best support.
I think is more with the support than anything else.
