Thread: 2500 Rear end 14 bolt?
    Would the rear end out of a 2500 hd work in a 99 1500 with a custom axle. That way I could have a good rear end that would just bolt in with the exception of a locker and axles? Thinking future mod here. Is the 2500hd rear end a 14 bolt or different animal all together?
    Thanks in advance
    Jake
    Jun 2007
    Ya know i went all through this,I cant remember it all tho.Iwould think so if you changed out axles,but if i remember right the axles were very pricey.good luck
    Pittsburgh, PA
    the 2500 14 bolt is too options....one is a 10.5 and other is 11.5. depending on what motor it came with is what size it is.
    entirely large rearends....not needed and probably to much work to make them work
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
    your more then likely going to find a 9.5 14 bolt sf the diesels have the 11.5 but thats not even a gm axel. and the 10.5 isent made any more, used to be in the older 2500.
