Thread: Overheating Issues! Motor bad?
    Saint Marys, GA
    I drove my truck into town today and noticed that the temp was about 235 degrees when I was cruising on the highway. It has always stayed under 210 degrees until now. I played around with it a little and figured out that when I get in the throttle (build up boost) that the temp drops back down the normal operating range. About a month or two ago I had to replace piston number 7 due to running my motor lean (over boosting) and breaking the ring land. The valve seat on the head was beat up a pretty bad but I tested it for leaks and it didn't leak. My truck is starting to idle a little rough again like it did right when the ring land broke and every now and again it will smoke especially if i just let my truck sit and idle. Does anybody know what's going on here? Any help is greatly appreciated!
    Also, could I be lucky enough for it to only be my thermostat going out??
    Current Mods: 6.0/4L80e with Trick Performance Front Mount
    Audio: Pioneer avic-d3, Memphis Belle, Two 12" Rockford Fosgate P3 shallow mounts, Memphis MS-Qs, and custom vinyl enclousure.
    Possibly a tstat but more likely a head gasket. Get a block tester.
    newburgh, NY
    Do a leak down test on all of the cylinders to test the head gasket.
    Step 1. crus at it.
    Step 2. get a hammer.
    Step 3. torch it.
