Thread: SkAkEsVHO Garage
    Nov 2006
    Cajun Country
    SkAkEsVHO Garage
    MY 2005 Silverado VHO
    Vehicle Build Model: CC15753 2005 Silverado LS 1500 2WD Ext Cab - Order Number: HWJV1C - Build Date: 02/08/2005 - Build Plant: 25153 - OEM Headlights And Driving Lights Painted Outer Edge To Match Truck, Special Thanks To John AKA KellyPerformance Took Lights Apart Shot 3 Coats Of Paint 2 Coats Of Clear And Baked Seal - Rear OEM Tail Lights And 3rd Brake Light Smoked - Street Scene Front Bumper Cover SS Style Generation 1 #95070144 - 06 OEM SS Front Grille(Paintable) #15276049 With Shopman1 VHO Bowtie - Speed Grille Inserts Main Grille #95077158 Lower Bumper Inserts #95077143 Finish In Satin Black - 06 SS OEM Mirrors Right Mirror #88980721 Left Mirror #88980722 - Driver Side Switch For SS Power Fold Mirrors #15883322 - GM Door Handles Painted - Sir Michael's Steel Roll Pan Welded And Molded - Precision Flip-up Licence Plate - Sir Michael's Roll Pan Hitch Class III - 22" X 10" Factory Reproductions Inc Chevy SS Sliverado Rims 305/40 Hankook Tires - Fabtech Bed Angled Spare Tire Mount - Tailgate Handle and Top Cap Shaved - Python 2-Way Security And Remote Start System With Responder Technology (PYTHON881XP) - OEM Chevy Silverado Instrument Panel Bezel (GM17802029) And Center Dash Console Bezel (GM12499984) In Brushed Aluminum - White SS Gauge Cluster CPO1008 from Factory Performance Products - OEM Leather Front/Read Dark Graphite Seats - Custom Plush Lloyd Carpet Floor Mats Black With Silver Trim And Silverado Stamp On Front And Rear Mats With A Set Of Lloyd Clear Overlay Mats - Hotchkis Performance Front And Rear Sway Bars #2231 - Bellteck 2" Lowering Spindles #2508 - Hotchkis 4" Lowering Leaf Pack With Special Carrier Bearing Bracket, Transmission Spacer, Shims And Polyurethane Bump Stops Are Included With Each Spring Set. #2403 - Bellteck Street Performance Shocks Front #310400BLT Rear #22112FF And Belltech Urethane Drop Bumpstops Front #B4922 Rear #B4923. - Airaid Cold Air Intake System - SLP 160 Thermostat, 2004-07 Corvette/2005-06 GTO/2004-06 4.8/5.3/6.0 Silverado/Sierra/SUV/2007 Classic/2006 Trailblazer SS - Keystone 06 Good Hood Twin Scoop Functional Ram-Air Hood High Strength Fiberglass Composite Construction. Steel Reinforcement For Added Durability #GHG121 -
    Magna Charger RADIX Intercooled Supercharger Kit, MP122HH Silver Satin Finish, 90mm Throttle Body With Dr. X Harness, 60 lb Injectors, Stock Pulley 3.4" On At This Time - Replacement Oil Takes 4oz. GM #12345982 Supercharger Oil - Carbon Fiber Radiator Cover And Carbon Fiber Fuse Box Cover - Thanks To Art AKA 12'SROCK - Performance Carbon Products - Metco 100mm Idler Pulleys With Extra Idler Spacer #69-90-57-001 - Pinned Crank Pulley - Custom Milled/Ported/Heads/Valve Job Spec. To Work With GT7 Cam - High Output Oil Pump - ARP Bolts (Top & Bottom End) - NGK TR6 Spark Plugs #NGK-4177 Gap To .035 - AeroForce Interceptor OBD2 Scan Gauge, Duals Can Moniter 4 Parameters At A Time, BLK Bezel White Face White/Blk Display, And Magna Charger Boost Gauge 31-1400-007 Custom Fit Top Mount Three Gauges Dash Shell With Paint Match Finish - PLX Wideband DM-100 + SM-AFR Universal Digital Display Module And Air/Fuel Sensor Module Combo Universal 2 1/16" (52mm) Gauge And Air/Fuel Sensor Module - Bosch Wideband Oxygen Sensor Type A - Autometer Phantom White Face Analog Clock Gauge #ATM-5785 - So-Cal Black Anodized Overhead Console Two Gauges Mount With Switches - Blower Cam Lingenfelter GT7 208/230 .554/.546 121 - Comp Cams Gen III/LS1/LS6 Pushrods 5/16 7.400 Length - Comp Cams Hi-Tech Roller Timing Chain Adjustable - GM Performance Parts LS6 Valve Springs. - ***Extensive Engine Dyno Testing At Lingenfelter Has Produced Some Of The Best Street Camshaft Profiles Available For The LS1, LS6 & LS2 Engines. The Lingenfelter "GT" Series Camshafts Were Designed To Produce Excellent Power While Still Producing A Smooth Idle For Automatic Or Six Speed Manual Transmission Equipped Vehicles That Can Be Daily Driven. - This Camshaft Was Designed To Be Used In Supercharged Or Turbocharged Applications In LS1, LS6, LS2 350 CID, 427 CID Engines - MSD 8.5mm Wires #MDS-32829 - Dynatech SuperMAXX Stainless Steel Header System w/ High Output Cats #115-841300 - Flowmaster 40 Series 2 In/2 Out Muffler Turned Out The Side With Duel Tip - Custom Built 4l65e Transmission In/Output Shaft Upgrade w/PI 10.5" 2400/2600 Stall Converter - RearEnd Detriot TrueTrac - T/A 1803 Rear Cover - 3.73 Ratio Gears - Calvert CalTrac Bars #3400 - 6" Billet Radio Antenna Satin Black #6206ALLK - Tune Dyno By Futral Motorsports
    07.01.08 laying color 2 coats and 6 coats of clear
    DD: 2008 TB LS
    2005 Silverado VHO
    Nov 2006
    Cajun Country
    Pics
    Mar 2006
    Mesquite
    Who is skakes?
