Results 1 to 10 of 44
Thread: Rearend Guys inside please!
    May 2006
    Waco TX
    Ok, so yesterday I was a truck gathering, and well I got a little stupid. Did like half of an all wheel drive burn out, which I am sure put some strain on the g80.
    I left it where it was for about 20 minutes not knowing anything was wrong. I went to leave and it felt like one of my back wheels was skipping, its hard to explain. Like it would lock and unlock. I could hear it drag on the pavement and the losen up and then drag again. I was only going about 5 mph. I was about to stop, and it made a loud pop noice, loud enough that the guys in the paking lot heard it also. Then it was fine after that. I drove it about 10 miles home and heard no noice on the highway.
    So do you think I have something wrong? Or did it just get put in a bind because I did the donut?
    Slimsilverado Guest
    uhh you probally broke something in the Gov-Bomb-80, pop open the case and see if any parts are laying in the bottom. GET a TRU-Trac
    May 2006
    Waco TX
    Quote Originally Posted by Slimsilverado View Post
    If something broke, wouldn't it make some type of noise? I drove it this morning, and it sounded normal, no odd sounds. I semi got on it a few times, and it felt normal, not sounds.
    Victoria, TX
    something was probably dislodged and catching in your spider gears or ring and pinion. Pop the cover and check worse case you just did a fluid change for no reason
    2011 4x4 6.2 Silverado ltz 6" fabtech lift 20" XD spy 35" nitto mud grappler
    Jun 2007
    pop the cover ,youlle see the pieces in the bottom,ask me how i know?
    May 2006
    Waco TX
    Quote Originally Posted by Ramsey View Post
    So how do you know? Haha
    So its pretty much gone? even though it is acting fine now? Thats what is weird about it.
    Oct 2007
    Bandera, TX
    yep
    single digit street truck
    for build info
    Fort Worth, Texas
    Time for True Trac!
    2002 Silverado 2500HD LB7 CCSB LT
    EFI Live by Rob at ATP, Edge CTS Insight DSP 5 control, S&B CAI, PPE boost valve, Pro Fab AIH, AirDog II 165, PPE WIF sensor delete plug, 5" stainless exhaust, Cognito braces & HD tie rods, H2's 315/70 R17 BFG's
    2004 Tahoe LT
    2006 Silverado Z71 LS
    1971 Chevy C10
    Jun 2007
    it only takes five minutes ,go ahead,pull it.get it overwith.
    May 2006
    Waco TX
    Ok I will do that and look. What do I need to pull it, ive never pulled a cover off. I know tools. But Gaskets? Fluid?
