Results 1 to 10 of 11
Thread: Mobil1 0 weight.
    Mar 2008
    Burleson, Texas
    Mobil1 0 weight.
    I was looking at the Mobil website the other day and saw that they have some new "Advanced Fuel Economy" that is basically 0w20 or 0w30 meant to replace regular weights. Seems like the thinner oil may lower oil pressure but I am pushing 55psi at 1000 RPMs anyway. Has anyone tried this yet? Or any type of 0 weight?
    PS. If any of you use Mobil, they've got a rebate on their website for $10 off a 5 quart purchase.
    '00 Silverado 4.8L (Gone)
    '11 Silverado 4.8L
    Quote Originally Posted by RUFFNECK View Post
    ...First relieve the pressure before doin' that or else you will get a nasty squirt and may get in ur eye.
    san antonio, tx
    Quote Originally Posted by yournamehere018 View Post
    1. i put the 0w-30 in my canyon. didn't notice any difference...good or bad.
    2. thanks for the heads up on the rebate.
    2008 Black RCSB Sierra 4.8L
    14.78 @ 90.93 mph
    My Garage
    san marcos,tx
    ive been using 0w30 for 2 years now and i can tell a difference with it. Using it has given me an improvment in fuel economy but it has also quieted down the noisy lifters i had.
    Pittsburgh, PA
    that is a thin oil for the colder states. a hot state like Tx i wouldnt use it in that state.
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
    San Marcos Texas
    I've used in 2 trucks. Didn't see any difference good or bad like stated before.
    Dec 2005
    Chicago-ish
    I used Mobil 0W30 when my truck was stock and you could hear the lifters a little with it.
    It sure goes down the funnel fast.
    2000 Sierra 2500 HD. 408 (11-2007) Whipplecharged, Big (18x24x4) FMIC.
    wichita falls, tx
    i run 5w-30 and thanks for the rebate!!
    i just printed mine off
    Intro Radicalli's
    Yep. M1 5W30 here. Change the oil annually in the Denali and 3 times per year in the Blazer.
    Winnipeg, Manitoba, Canada
    X2 anything above 45*F i wouldnt use it.. Its meant for winter and extreme cold.
    Well DUH. The viscosity index of the oil is the "thickness" and is soley dependent on the temperatures in which it will flow. The lower the viscosity number, the thinner the oil. We all use multi-grade oil, hence the 5W30 designation. The "5W" is the cold start viscosity (0W is at -35 degrees Celsius, 5W is at -30 degrees Celsius, and 10W is at -25 degrees Celsius) and and the "30" is the viscosity of the oil at 100 degrees Celsius.
