Results 1 to 10 of 14
Thread: Wiring of the OBD2 connector?
    Spiro, Oklahoma
    Anyone know the way to hook one of these up? This is what I've found on it so far but I just wanted a second opinion before I do it.
    PIN 2(PURPLE, some diagrams stated it's GREEN) data from pin 58 serial data.
    PIN 4 (LT BLUE/BLACK)ground
    PIN 5 (DARK BLUE)ground
    PIN 16 ORANGE/BLACK)power at all times.
    It just didn't sound right to me, it seems like there should be more than one wire going to the pcm and why would there be two that go to ground?
    Pittsburgh, PA
    thats about right. i know on the standalone harness's ive made i only used 4 wires. power, ground and signal.
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
    That's French.
    The comm line is purple, power is black and/or black and white...what else is needed?
    Pittsburgh, PA
    That's French.
    thought the black was the ground and the orange was the hot? iid have to check my diagram i made up to varify this
    412 Motorsports
    Oops. Missed some words
    Orange is power. Black and/or black and white is ground. Some have both.
    Thanks George.
    Spiro, Oklahoma
    Mine doesn't have any black wires.
    Your OEM ALDL has no black or black/white wires?
    That's weird.
    Duh! No it's not. You have an OBDI '91. Did your swap harness come with an ALDL?
    Spiro, Oklahoma
    It came with the reworked harness I bought but wasn't connected it only has the four wires listed in the first post.
    There is only one wire needed to the data bus. On an older truck, there is no other Class2 devices besides the PCM so it only needs to go to the PCM. Many components have redundant grounds. It needs power and ground for the scanner.
    Hutto TX
    get it workin low91?
    1991 Silverado ECLB
    LM7-T56
