Results 1 to 10 of 25
Thread: 5.3 to 6.0
    Jan 2004
    I have a 2000 silverado 1/2 ton. Want to swap to a 6.0l. Anyone done this swap or know anything about 4l60e trans capability & pcm- do I need a 6.0l pcm? Is trans. controlled w/ engine pcm?
    Sep 2003
    Cedar Park, TX
    Lots of people have done this (if you already have a 4.8 or 5.3). Direct swap and bolt up as long as you get a 2000 6.0(I think)and up. somewhere in there they changed the crank and you want the newer one.
    Stock pcm will run it, no problem. For optimum performance, have Allen tune it.
    '02 1500HD, 6.0L, magnacharger, 2000stall, custom magnaflow with electric cutout, E-fans, Nelson custom tune, Auburn LSD.
    '79 L82 vette, Summit 355, Dart Pro1 heads, Comp 274 cam, Holley TBI, Built TH350 with 2500stall
    '93 Blazer, full size 2dr 4x4, new project.....
    If you can pull the engine you can do the swap. That is the hardest part.
    Here's a little tip, remove part of the steering column that is in the way of the driver's side engine mount. It makes it a lot easier to get the engine in and out.
    thanks l82gofast,
    oh ya, a tune will really make it run, hehe..
    allen
    Mar 2004
    Wanting to do this swap as well.
    Where should I start looking for this motor?
    I want forged internals (pistons, rods, etc.). Who sells these as well?
    I also want to cam it. Which cam is preferred...I need it streetable....its an everyday driver.
    What all will need to be bought to switch over to the 6.0 (LQ9)?
    Allen, can you help me with all this?
    '99 5.3 X-Cab (Looking for BLACK straightbed to trade for my sportside)
    Performance: Nelson Dyno Tune, K&N FIPK, Hooker Aerochamber True-Dual, MSD Wires.
    Work in Progress: 6.0L, 4L80E w/Transgo & Yank 2600HD, Comp Cam 218/220 or something with 560 lift & LSA 115, Valvetrain Kit (rods, springs, retainers), TOG Headers, B&M Supercooler, 160 Stat, 42lb Injectors, Eaton Posi w/3.73s, LS1 Fans, 150 Dry Shot NOS-5176 w/NGK TR6-IX Plugs, NELSON RE-TUNE!
    Mar 2004
    Oh yeah, did I mention that I want one made near bulletproff?
    Dec 2003
    you want atleast a 01 block any 6.0 block older than that you cant bore out more than .oo5. I had all my work on my truck done at (www.speed-eng.com) they do good work. There building 2 4wheel drive ext cabs on 36s right now. ones getting 6.0 swap forged internals lunati rods cam patriot heads and a radix it supose to be around 600hp. then the other truck is doing a built 5.3 for lots of nitrous. There just trying to get there name out right now so there doing stuff cheap.
    old set up: 2002 chevy 5.3, procharger 12lbs boost, asm headers, ls1 edit, flames, 20inch budniks
    New Set up: 2004 chevy 5.3 ext cab, 12 inch twisted suspension lift, 36's, exhaust.
    future mods: 150-200 shot, ls1 edit, air intake, stall, 5.13 gears, 12s or bust
    Mar 2004
    That's good info to know! Thanks.
    Where should I begin my search for one? I've checked eBay with no luck (used keywords 6.0 engine, LQ9, 6.0 motor, looked in the engine category, etc.
    What aftermarket parts (details) are good with the 6.0?
    Cam
    Headers
    Heads
    Dec 2003
    I can get one for around 500 to 600 thats brand new.
    Mar 2004
    where?
    Hey, your truck is going to haul ass after we're done with it.
    I just sent you an email with all the parts list.
    talk to you tomorrow.
