Results 1 to 7 of 7
Thread: Any Resorces On Building A 650hp Ready 4l65e?
    P'cola Fl
    Talking Any Resorces On Building A 650hp Ready 4l65e?
    So my 03 sierra is pushing 80k and since i'm planning on a ls6 w vortech swap (hoping for about 650hp to the flywheel after all is said and done). I want to go ahead and build the hell out of but i really want to stick with a stock stall since i still drive it everyday and tow often. Any links or advice would be great, thank you in advance you guys always come through with great advice and help once again thank you!
    Apr 2005
    FLT Level 5+ is for +/- 550rwhp. That should be = to your flywheel output.
    Gone, but not forgotten!
    Quote Originally Posted by SCIV View Post
    Finish Line Transmissions | Performance Transmissions | Power Converters | Transmission Parts | Transmission Service
    I would go 4l80 that way you don't have to worry about it at all when you decide that you need at least 800rwhp.
    Also keep in mind you get what you pay for.
    Nov 2006
    Mesquite, TX
    also kind of depends on your weight...heavier vehicle makes more stress on the trans...if its a scsb truck then you will have less to worry about...Sprayed99 his dad built my trans and it's held pretty good and i put 540/591 down in a 5,400lb truck
    Apr 2005
    Very true.
    Jun 2007
    do an 80e ,trust me ive done 7 60-65s.
