Results 1 to 7 of 7
Thread: check engine light
    Apr 2003
    The check engine light went on for the third time, a friend that works on a gm dealer told me that it is because of the cam swap and it's weird idle, and that I'll have to live with it because no matter how many times he erase the code it will come back on.
    It doesn't make sense to me since Allen fixed idle with his tune.
    So, is there a way to fix this with LS1edit?
    Other options?
    Thanks.
    STOLEN: 2005 SILVERADO 1500 4WD ECSB 5.3L 3.42 gears
    Sold: 2003 SILVERADO 1500 RC STEPSIDE 5.3L 3.73 gears
    Fort Worth, Texas
    Does the SES light come on steady or does it flash? Have you had the code read yet? Sounds like a miss fire code to me. Allen should be able to fix it with edit, he did my edit and I had a few codes that he fixed. You shouldn't delete the codes you need to have Allen make the adjustments for them in edit.
    2002 Silverado 2500HD LB7 CCSB LT
    EFI Live by Rob at ATP, Edge CTS Insight DSP 5 control, S&B CAI, PPE boost valve, Pro Fab AIH, AirDog II 165, PPE WIF sensor delete plug, 5" stainless exhaust, Cognito braces & HD tie rods, H2's 315/70 R17 BFG's
    2004 Tahoe LT
    2006 Silverado Z71 LS
    1971 Chevy C10
    May 2003
    2005 RCSB 4.8L TVS1900 9 psi
    2005 ECSB 4.8L TVS1900 5 psi
    That makes 9.6L @ 14psi
    Dec 2003
    how bigs you cam?
    old set up: 2002 chevy 5.3, procharger 12lbs boost, asm headers, ls1 edit, flames, 20inch budniks
    New Set up: 2004 chevy 5.3 ext cab, 12 inch twisted suspension lift, 36's, exhaust.
    future mods: 150-200 shot, ls1 edit, air intake, stall, 5.13 gears, 12s or bust
    Apr 2003
    Thanks for the replies guys, the light comes on steady, the truck works fine, but I'll check the plugs and plug wires any way.
    blown02, the cam specs are 212/218 .557/.562 lift and 114 lsa
    Thanks.
    Fort Worth, Texas
    Does your idle surge at all?
    2004 Tahoe LT
    1971 Chevy C10
    Dec 2003
    yea you should be able to turn it off with edit no problem
