Wooooo got it out finally, let my roomate, a certified GM tech get in there, i took everything apart, and put it back together, he did the welding.
Basically the Bolt out wouldnt grab it, GM dealer said it needed to take the heads off to drill it out twice the size then coil it back down to that for 1200 F*ck that, so
Basically he just built up a little weld, turned it out, like clock work.
If anyone else has this problem, try it, it was completely worth it.
