Thread: Stock trailblazer stall?
    Southern WI
    I've noticed that some of the guys on here run the TB stall, an I searched ebay and you can get them really cheap. I just wondered what the stall was on one of those and how big of a cam can be ran with one? (the one I'm looking at is .525/.525 112 )
    Mike
    2000 RCSB
    Nov 2006
    Mesquite, TX
    whats the duration on the cam, that also has an effect of the size of stall you need, you can usually get 2400-2600 stall out of a tb stall
    Southern WI
    The duration is 219/228. I can guess that I would be able to make more power from buying a different cam and thenthe springs and all that seperate, but with limited money I kinda gotta go with a "package" deal for around $450. Do you think it's be a waste of money and I should go with a different setup or will it work good. The mods when done will be basically cai, lt's, full exhaust, the cam/springs, a stall of somekind and a good tune. I'm open to any and all suggestions!
    Mike
    2000 RCSB
