Results 1 to 7 of 7
Thread: Pacesetters LT Exhaust setup
    Mar 2008
    Ok so here is a long story and ?s from a newb. I just purchased an 06 Silverado Ext Cab 4x4 with the 5.3, I haven't picked the truck up yet because I am overseas but I rushed in like a fool and ordered Pacesetter LT headers to start on the exhaust.
    So now the ?s could this setup work if I found a decent exhaust shop to run duals to an X pipe muffler?
    These Headers
    To a 3” to 2.5” collector reducer like such then from the reducers I assume we would need custom bent tubing for the high flow aftermarket cats with like these with the 02 bungs since I guess from what I could find out online the factory system uses 4 sensors 2 prior in the headers / manifolds and one in each cat and I assume we could use OEM style replacements so it doesn’t throw codes
    Then from the cats we would need custom bent pipes to a Dynomax Ultra-Flo X muffler 2 in 2 out and, then run 2.5” pipes from it from there to split rear exit and maybe some nice tips.
    Anybody with any input would be greatly appreciated.
    Feb 2008
    Bowling Green,KY
    man i don't see any problems with doing it. I have these headers but i just ran a full 3inch exhaust all the way through mine for a little more power over the 2.5inch piping. Delete the cats and do the x-pipe! But is it an extended cab? A lot of my buddies have Silverado SS's and they run headers with true duals and an x-pipe!
    5.3,Trsnsgo HD2 Shift Kit,Vette Servo,K&N CAI,Pacesetter Long Tubes,Off Road Y-pipe,Flowmaster Super44,MSD Wires,Fusion Plugs,TB Spacer,TB Coolant By-pass mod,HP Tune,100 Shot Wet Kit,Air Ride Suspension & No Traction what so ever!!!!
    Mar 2008
    I am running the reducers because from my understanding 3 inch pipes decrease backpressure too much, I am sticking with the cats because I am having a shop do all the work and they won't touch it without cats. This is all in prep for a Radix install come June.
    May 2006
    Waco TX
    I have the same headers with 2.5 inch pipes, dual magnaflows and no Xpipe. Suounds pretty good.
    Mar 2008
    Yeah I am just worrying about eliminating the Y pipe pretty much with it being 4x4 and the amount of space available
    May 2006
    Waco TX
    Quote Originally Posted by Trashed666 View Post
    It wont be a problem. Remember my truck is AWD, so we have basically the same drivetrain. There is plenty of room.
    Yeah, what you have explained sounds just fine. I would not drop down to 2.5" right at the collectors--I would wait until the muffler to do so. I would also HIGHLY recommend that you get 2 sets of these 3 bolt flanges and gaskets so that the exhaust shop can weld these to the ends of the header collectors where it meets to the 3" y-pipe. This will make it much easier to assemble and disassemble if needed. Inside the 3" y-pipe, have them install 3" high flow cats with the proper O2 bung locations. And run the 3" y-pipe to the socket joint to where your cat back meets up. From there, you can reduce the 3" to a 2.5" Y and then into your 2.5" dual in/2.5" dual out x-pipe muffler.
