Results 1 to 10 of 13
Thread: patriot stage 2 lq9 heads 72cc
    Oct 2007
    weatherford,TX
    i bought these heads a few months ago for 825+shipping thats all i want for them , the guy i got them from only had them on for 750 miles there is nothing wrong with them at all just not what i need for my setup not need the money for converter
    [SIGPIC]5.3 k&n cai ,asm lt, hf cats, aero turbine muffler, vhp 216/224-551/551-115lsa, tbss intake, ls2 90mm tb,tb bypass, comp double roller tc, hv oil pump, ls2 injectors,nelson tune, b&m super cooler, taylor 10.4mm wires, ngk tr55ix, 373 Detroit tru trac,
    ff_jeff Guest
    what valve, springs, and pushrods does it have?
    Apr 2003
    Mansfield, Texas, USA
    Thumbs up
    Quote Originally Posted by vff_jeff View Post
    2.02/1.57s... pat duals/Ti retainers... why would it have pushrods?
    ff_jeff Guest
    I thought it might come with some. hehehe just wish ful thinking. IM looking at options for a tax return upgrade and I might just scoop em up. If they will fit. IM not totally sure if the will be what My little 4.8l needs. what do you think?
    Apr 2003
    Thumbs up
    Get a cam first and some smaller primary headers along with a converter before jumping into heads.
    The deal is awesome on those heads.
    ff_jeff Guest
    If i got the cam i would probably get heads at the same time. I was thinkin that it would be easier to swap a cam if the heads were off any ways. I was just worried about the combustion chamber being the wrong size and the compression ratio being off. The stall wont be for a while.
    Dec 2003
    Azle,TX
    Jeff...heads dont come off to do the cam.Very little parts are removed in a cam swap
    Vortec Performance Tuned
    has these heads been milled any? reason i ask i have the patriot 5.3 stage 2 heads on my lq9 which has put my cr at or around 11:5:1 maybe a slight more.. jut wondering how much of a change it would by with these heads ..i wanna stay around 11:1 cr for N/A
    Simple: 408 on steroids!
    single digits coming soon!
    Jun 2007
    Quote Originally Posted by 06-crewhauler View Post
    pm sent
    Oct 2007
    weatherford,TX
    skeet these heads have not been milled at all bought the heads from patriot put them on a fbody rapped it around a pole he took them off i bought them
