Originally Posted by
Quik
i am going to run 2 or 3 walboros with lights to tell me if all 3 are working. as i see it they are quiter and can be used in stock location. I prefer the cleanest apperance ever. those other pumps arent for me. walboros are cheap and easy to replace. now if i had an all out drag car then yes i woudl run a top of line high pump like that. but its been proven over and over again that walboros make 1000 hp. so for anybody like you and me walboros are all that is needed
hope u have better luck with walboro than me ,i went through 2 in 2 weeks.
